Power steering fluid vs transmission fluid
cabinetmkr39
We had our steering actuator replaced this season mechanic told us to use ATF to refill and we remove air. Why would I not use PS fluid? I did not have a chance to ask mechanic. So I’m posting here. Thank you in advance.
matt167
Many power steering systems run ATF as a fluid. Depending on which marine power steering system we’re talking about it’s an acceptable choice
You can run ISO 32 or 46 hydraulic oil, ATF, UTF, SAE 30, or PS fluid. Pump dont care, actuators don't care.
Volvo has spec'd nearly all of them over the years
Just flush the system between fluids as some of the chemicals in PS fluid don't like some of the additives in other fluids
Texasmark
I don't recall the official source, may have been my service manual but it said: If you pop the cap and see red, top off with ATF. If the oil is clear, install PS fluid.
