flyhigh123
- Nov 17, 2012
- 112
I've owned my boat for about 1 year now. I've always felt that my power steering was way to stiff At idle, i can barely turn the wheel. Once I get it up to 2k RPM, it turns much easier. Was hoping to be able to easily turn the wheel even at idle so that I can manuver better.
How do I tell if its the pump thats going bad? Could it be the actuator or moreso the pump? I'll check the belt tension as well. I'll check fluid levels.
For those with a similar setup, how does your power steering feel? Is this normal?
