76SeaRay
- Aug 24, 2017
- 1,071
Does anybody have some pictures that show how their power steering pump is mounted (5.7L with PS Pump high on starboard side)? I have two bracket sets (cast bracket 1988 to 1995 and stamped bracket 1996 to 2002). I want to use the stamped bracket as it looks to be a better bracket. However, the parts diagram for the 1996 5.7L shows the PS Pump with mounting studs. The used pump I have has studs but there seems to be no way to get the pump into the bracket with the studs in place. As a side note, the used pump has a Mercruiser pulley but it looks like and automotive pump (return tube high on the back side. I ordered a new pump with the correct tube and it comes with bolts in the back and not studs. Anyway, looking for pictures.
