Power Steering Pump question
MH9371B
It appears I have a leak in my power steering pump. The fluid actually leaks out while the boat is sitting in my driveway.<br /><br />My question is, will running the boat with no power steering fluid adversely affect the engine in any way?<br /><br />1995 Merc. 3.0 LX 135HP
rabidfish
Re: Power Steering Pump question
It wont hurt the engine, but it will ruin the pump.
Well,....After the Pump Seizes,..... The Belt Breaks,+ the Alt. Stops turning... Along with the Waterpump,+ Anything else driven by the belt.......<br /><br />You've Got to Fix It,.......... Now is Better than Later........... ;)
It may be as simple as a leaking fitting. If it leaks with engine off, it's likely a return line or a shaft seal. Do the simple things first. Check the lines and fittings.
MH9371B
Help me out here, what is a "shaft seal" I see two hoses going into the back of the pump, both clamps are very tight...
waterone1@aol.com
If you wipe the unit off, and re-fill it with fluid, where is it leaking from ? If it is leaking from the front, where the pulley is, it is most likely the shaft seal, which means time to replace the pump.
