Re: Power trim - Filling from empty
lower the motor all the way<br /><br />Fill up the reservoir with oil<br /><br />Unscrew the bleed screw half way so the screw is in though it will let air/oil through i.e partially unscrew it.. This could be a bolt on this motor<br /><br />Press the button that raises the motor until oil comes out from the screw/bolt u underscrewed<br /><br />Screw the screw back in as now you have let all the air out.<br /><br />Should work good now.. You can always bleed it more if it runs ****
