Re: Power Trim Question
Logan, the trim relays are located in a black box mounted on the exhaust cover...on the back of the engine. Two screws hold the lid on. When you open it up, there will be two relays laying in the top. They are plug in relays so just grab the socket and pull the relay out.<br /><br />Clean the stabs and replace....both relays are the same...and see if it works.<br /><br />If it don't, look for the two stab connector coming from the box....it'll have a green and blue wire. These leads go directly to the TNT motor. Pull the connector apart. The motor runs forward and reverse depending on which way the polarity of the battery is switched to it.<br /><br />Green wire is up, blue wire is down. To check the motor still runs, use jumpers and apply 12V from the battery to the stabs on the connector leading to the motor. To go up, connect the green wire to battery negative and blue wire to battery positive. You should hear the motor run and the motor should lift. To go down, reverse the leads to the stab connector.<br /><br />Let us know what you find and we'll go from there.
