power trim removal of center cylinder
acadian2022
good day all. could someone explain how to remove single center cylinder for a replacement see pictures. I see the top part will be a pin to knock out its the bottom one not sure how to go about it. thank you all
airshot
I have q manual, but for a much smaller motor, so probably can't help
acadian2022
hi all. I assume I need a puller of sort my concern this is was used as a salt water engine and when I removed those covers to expose the center pin with center threaded hole I'm assuming it's going to seized had slat deposits inside of the cover. will spray penetrate WD-40. I have another post regarding this engine wanted to seperate the topic thank you once again for any help on this.
acadian2022
perhaps the center hole is a reverse tread bolt that is required?
acadian2022
I think you put a threaded rod in there.----And a slide hammer.----Perhaps your local friendly shop will pull it in minutes.
acadian2022
I was thinking about that... and have such a tool :) what the heck will give that a try thank you...
