PowerPack or SwitchBox Question
krakatoa
Hello Guys!
There is anyway to test "on bench" a powerpack? Any info about this?
This is a Mercury Quicksilver Part Number 3325772
Thanks!
No economical way to test it at home.----Generally you test the components that feed into it.-------What is your motor doing / not doing?
Faztbullet
Here is test card that will check everthing but internal rectifier and capacitor......
krakatoa
You have a point, the engine crank but doesnt start. I already install a new powerpack and mow its start just fine. My concern is that i changed the powerpack brand new on Jan 2014 and in less thana year have to install another one. Important to mention in Jan 2014 also installed the stator, trigger and starter too.
The powerpack just died without any signal or warning...
Have you looked for issues with the ignition switch " kill circuit " and the wiring harness from control box to the motor ?
