270sundancer
- Jun 16, 2008
- 13
Thanks for evryone's advice on my sudden "dying" problem. I'm going to check fuel lines for blockage and shifter/throttle assembly for "man overboard" kill switch short/problem, etc. I would like to know if when I disconnect the fuel line from where it attaches to the filter/seperator housing, will it try to empty the fuel tank when I unhook this line? What  can I do to prevent fuel from flowing when I unhook this? Also, I will need to remove the shifter/throttle assembly from the side of the fiberglass by the helm to check the kill switch as it is not accessible from anywhere on the back side. Is there anything I need to be careful of when removing it and replacing it after inspection, such as alignment/etc. Thanks a TON GUYS!!
