rolmops
- Feb 24, 2002
- 5,686
Re: preferred trout/salmon lures
The 10 color would do well for the deeper water.It will get you down to about 45 feet, but it will not help you much for the browns because you want your lure to be about 150 feet behind your boat if you don't run side boards and that would mean 4 colors which will get you down to 20 feet and that may be too deep.On the other hand 10 colors with a flasher and lure will get you into Cohos.
As for the line,try to run about 50 or 60 feet of 8 pound or maximum 12 pound line with a loose drag. It has been proven time and again that browns do not like line much over 8 pounds in fairly clear water.
As for your 17 foot Niagara.You may want to leave it at home if you plan on the Niagara Bar. A trip like that is usually way more successful when you hop on a charter. 10 foot waves are not uncommon and added to that are some quite nasty currents around there.
If you go after the steel head and Cohos,with the occasional laker or king mixed in,800 feet of 20 pound line will be your ticket. LOL I have caught 29 pound kings on a 20 pound line,just set the drag loose and let them tire themselves out.
