ChrisSmith290
- Jan 7, 2016
- 28
Hi, I'm trying to figure out where to start on a slow leak on my alpha one drive. I put 12 psi in the drive, 45 min later still at 12 psi. When I turn the yoke assembly clockwise the pressure drops to 11.5 and stays there. I had gear oil in the bellows that was coming from a groove in the small yoke, when I took the drives off for the winter ,about 4 ounces. The drive wouldn't hold pressure for 30 seconds when I took it off. Naturally I replaced the oil seal on the yoke too. No water in the oil when I drained it. I replaced all seals three years ago. My question is what might be leaking that would only only leak when the shaft it turned? Thanks in advance and looked around this forum a bit for something like this but couldn't find anything. Also I replaced the same on the other drive and it's perfect. They are twin 4.3's on a 1988 30' cruiser.
