pressure testing outdrives
big ken
i did a pressure check on lower half of my mc1 and found that air was leaking at shiftshaft bushing, not a big deal. then tested upper, leaks down fast but cant find any bubbles when spraying with soapy water. where are the upper units likely to leak at? thanks ken
Don S
Re: pressure testing outdrives
There are only a couple of places it can leak. The seals where the vertical shaft from the lower goes into the gear, and the input shaft (ujoints shaft)
The cap oring could also leak.
Do you have the upper off the boat?
big ken
yes don they are off boat and seperated. as far as the cap oring goes i sprayed soapy water on it and seen no bubbles[was hoping to though] figured that woulb be an easy fix
and seperated
Ayuh,....
Put the 1/2s back together....
The seal in the upper can't seal against the vertical shaft, if it isn't there....
gregstukey
When re-sealing a drive, is it necessary to pull the whole drive apart and re seal even the bearing seals? or is it just a few critical locations that must be addressed (and where might they be on a Volvo sx drive?)
Also, sorry about post hijack, but I have a customers pinion bearing housing that siezed in the pivot housing actually severing the pinion bearing housing at the 4 bolt holes upon drive removal.
Can I rebuild the pinion bearing housing using the old input gear shaft? Should I use what I can from the old set-up or build new from scratch? If i do rebuild from scratch can I at least re-use the input gear to avoid having to change the other corresponding gears?
and I have to do this x2 on a neglected salt water chris craft with Volvo SX drives.
rockyman
i have inline 6cyl 250 1978? 165 merc outdrive just had bellows replaced and was wandering if this would stop oil from getting into bilge . providing their was no oil leaking from motor itself . thanks
Don S
Come on guys, this is Ken's question, about his problem. if you have questions about your drive then start a new thread. There is no way either reply #5 or 6 should be here.
a70eliminator
soap bubbles aren't always the best route cause sometimes the leak can just blow the soap away and not make a bubble if it's a bad one, try submerging the drive in a tub of water then see what developes. I'm baseing this on years of experience with soap bubbles on refrigeration equipment, they don't always show.
big ken
Ayuh,....
i will get another shift shaft bushing assembly and a new shift shaft and try that. thanks
