greasemonkeyozi
- Jul 16, 2003
- 282
I have just posted one fault on a topic about a water leak on this motor, and figured I needed to create a new one since this is a different topic. <br />  I had bought this old 75 70hp 3 cyl and finally got her working right. So far, I have (1) replaced all frayed wiring and connectors and lubed all points to prevent corrosion. (2) replaced switch box and reset timing. (3) replaced spark plugs and repaired some exposed plug wires. (4) rebuild, reset, and tuned carborators. (5) replaced all hoses both fuel and water. (6) replaced fuel pump diaphram (7) Replaced prop with smaller one to prevent me from sheering it again. still get same performance though.(8) changed out lower unit gear oil and notice white milky color. Dont know how long it has been since last changed though.(8) ran compression test, all checks good at 150psi.<br />  Now that I have finally got her to run like new,"Knock on wood," have I missed anything as far as preventive maint. Any advise will be appreciated.
