Primer bulb issue
Jakem
I am having an issue with fuel supply to my 250 two stroke. I have replaced the fuel lines, primer bulbs, and the issue is the bulb pumps up hard but looses it's pressure. Also the same happens to my kicker line. Any suggestions
Jakem
It's a new to me boat and I'm sure it needs a good engine once over
Jakem
Seems when just trolling it chugs so I figured the primer bulb was issue. Runs smooth in nuetral however has a chug when going slow
Perhaps running lean on slow speed mixture?----Year / model # is ?---Carbureted or fuel injected ?
Looked at parts for 1994 models.----The 4 that I see list carburetors.-----Your model number is ?
boscoe99
All primer balls will get softer once the motor is running. The fuel pump(s) lower the fuel pressure within the fuel system from the pump inlet all the way back to the tank.
boscoe99
If and when the motor seems to not be running right pump the primer ball to force gasoline to the motor. You doing with the ball what the fuel pump should be doing. Does the motor seem to run better when you do this?
boscoe99
Is the model of the motor not known?
Is it a Yamaha or a Suzuki?
MMM. Motor Models Matter.
Jakem
It's a yamaha l250...TXRS....yes when I pump it up it runs better
It is shown with carburetors.----A new to you boat you say.----Do a compression test on this 30 year old motor.----Post the actual values here.
Jakem
This is what I got
boscoe99
Or perhaps a fuel injected model has been mounted on the frame of a motor that had carburetors.
Jakem
Definitely has carbs
Jakem
The bottom fuel pump continuously clicks as soon as I put power on. Also noticed that my air boxes are missing the o rings
No surprise.----See post #6.-----And I do not believe the fuel pumps are electrically operated.
