Primer valve
Jcrain
Hi, I got a 50 hp Evinrude, model E50TLCRM, serial # J043816. I was told this is an 87 model, but not real sure. Anyway, on the fuel primer solinoid there is a red lever. For normal starting and running, does the lever point toward the solinoid or away from it?
Dhadley
Re: Primer valve
CR means its an 1984. The lever on the primer will be parallel to the primer body for normal operation.
Jcrain
Re: Primer valve
Thanks, Dhadley. It runs lots better in that position
