nola mike
- Apr 22, 2009
- 5,782
Doesn't sound like you're having much luck. Guess I'd start with the ignition. What do you have on there now? If you're flooding, that might be the case of your no spark. Do you have spark from the coil? As for fuel, is the needle seating? You can blow in there with the float raised and see. If so, might need to check your fuel pressure next.
