jdparsons1
- Jun 22, 2003
- 16
I have a 1987 85hp Force on a 17' bayliner. It is running rough in low idle and dies some times and runs good at about 90% throttle but if you run at 100% it runs good for a few minutes then starts to lose power. If i pull off of the throttle and then give it gas again it will speed back up. I also noticed that it will tend to lose power when I hit waves which is kind of wierd. If it does happen to stall it usually starts right back up again but as I said will constantly die if you are going through a no wake area at low idle.<br /><br />Any Ideas???
