Re: Problem with startup on '97 mercruiser 454
Wow, where do I start! I feel like I've been initiated here. Thanks for the insight fellas. Schematic, I took some voltage readings today. Key on, engine off: The "S" wire coming from the regulator =12volts, the "EXE" wire from the reg. =12volts, the power wire reads 12volts and the wire also connected to the voltage regulator that travels to the electric choke reads 2volts DC, 4volts AC. Other than that there is a ground wire. The alternator seemed to generate voltage a little lower on the tach today(maybe 1500rpm), maybe that's more acceptable. Either way the choke didn't seem to open fast enought to prevent the motor from flooding even with the extra juice flowing to it. I wonder if it was somehow damaged by proping it open as a temporary fix. Although, if that was the case, I would think it would have a tendency to stay open rather that closed. Walter, you are more than likely correct. When there wasn't problem with the boat, I wasn't exactly studying the gauges as I am now. It's very likely that I just didn't notice the characteristics of the alternator. Thanks for the insight on the Mando alt. ODDD1. Makes me think I'm just too paranoid at this point in the game. As far as Schematic's philosophy on go with what you know, I agree. And I don't know jack about alternators other than I've never had to replace one in a car. And... I know inexpensive too. Unfortunately I don't have the option of returning the Mando once it's been installed and IF IT'S OPERATING PROPERLY. The flame arrestor kit for the Delco is a great fix that I will keep in mind in the future. Unfortunately, as in this case, my impatients sometimes gets the best of me and instead of loosing time on the water to search a salvage yard I buy new and have it delivered to my door instead. So... in a nutshell, I won't be using too many accessories, trolling motors etc. I suspect there is a problem with the electric choke now. I don't care for it enough to replace it so I'll bypass it. So I won't need to rev the cold engine to start the alternator. That will happen once the engine is warmed up and I'm on my way. So I guess i'm living with the mando. Wish me luck.
