I have problems with my 30HP outboard.It runs fine on Idle and starts immediatly. When I throtlle up a bit It seems like one of the three cilinders is getting cut off so there is less power an a wild shaking engine. I already changed coils and sparkplugs without result. The item that I don`t trust is the temperature sensor. Is it a sensor or is it a switch but then is it NO or NC. I can`t messure anything on the switch/sensor. No resistance and no switching when held in boiling water.
The dealer says that it is the pickup sensor failing. But then it should fail at all revs doesn`t it ??It seems like a sort of safety mode of the ignition unit , doesn`t it?
Has anyone any idea to help me out ???
Regards T de Wit
Regards T de Wit
