The plot thickens...
Found a cut wire on the mercathode. A ring connector with a rubber boot over it. Upon closer inspection the cut wire that went to the ring connector was Red with a purple stripe. Is there supposed to be a red with purple going to the mercathode?
When i first found the cut red wire a week or so ago I couldn’t get a good look at it and said it was a cut red wire (I didn’t know there was a purple stripe at the time). Muc guessed it would be for Mercathode if it was plain red. In the wire diagram I sent AllDodge I only see reference to a ground wire for mercathode, not a hot wire.
Questions:
1. Does the cut red / purple wire belong on the Mercathode?
2. If not, is another wire needed for the Mercathode before it will function properly?
If it doesn’t go to the mercathode then where does it go?!
