oldybutagoody
- Dec 30, 2011
- 207
Re: Resurrecting a 1957 Evinrude Lark (video). Need help shifting to forward
It can LOOK like it's connected and not BE connected. There is a grove on the end of the shift shaft that allows the bolt that goes into the coupler to thread into the coupler. The shift shaft has to be all the way up into the coupler before that bolt goes in. Otherwise only the tip of the shaft is in the coupler and it comes out with just a little force. Also, if the shaft isn't coupled correctly it will effectively be longer which messes up the adjustment. Your adjustments (Up at the lever) are probably not correct since you adjusted it while the shaft wasn't connected properly. It could be other things like the lever in the gear case or the screw that that lever pivots on but I'd put my money on the shaft coupler. Anyway, glad you have a spare motor. Hope it's a good weekend.
Yea I disconnected that and reconnected it a couple times, but still no luck. I'm hoping I just missed something when connecting it up... It is pulling the linkage up when shifted into forward, its almost like its just not pulling far enough up. I dont know... I got frustrated with it and just swapped out the motor to my '58 Johnson 35hp. After a little tinkering, I got that one running well and it shifts nicely so that's gonna be my motor for this weekend. The lark runs a little smoother at lower RPM's then the Johnson, and the electric start is really nice, but having a forward gear trumps electric start. Anyways, The Johnson looks like it will get me on the water this weekend, so right now, that's the motor of choice... I'll keep working on the evinrude later
