Spindle sleeve product review
The spindles on my boat trailer developed a slight, round grove where the grease seals ride. The seals don?t leak grease but I was still concerned that this would allow for water intrusion and lead to bearing failure. I looked into buying a spindle repair kit but none of the 3 local trailer shops carried them. I decided to order a spindle repair kit from bearing buddy. The kit consists of an upgrade grease seal, o-ring and a thin metal sleeve that slides over the spindle. The sleeve is supposed to provide a smooth machined surface for the grease seal to ride on during towing. It didn?t actually work for me. The problem lies with the metal sleeve. The sleeve doesn?t actually fit overthe area of the spindle where the grease seal rides. It?s not really a sleeve either; it?s a fat ring with some kind of lock washer/ expansion ring inside of it. The ring doesn?t really slide over the area of the spindle where the grease seal rides either. Instead it installs off to the side of the area. This creates a clearance problem with the hub. The hub won?t slide all the way on the spindled either. It will slide most of the way but not enough to properly adjust the castle nut. The castle nut properly tightened is now hanging over the cotter pin hole and prohibiting the installation of the cotter pin. Bearing buddy is aware of this problem and warns of it on the back of the package. I wish I would have know about this before I ordered the product and paid for shipping and processing. Bearing buddies? solution to the problem is to machine the castle nut to be slimmer or buy a slimmer castle nut. I think this is impractical and a bad idea. First off, what home mechanic has the ability to machine and polish a castle nut? Secondly I don?t want a slimmer castle nut. I want the one that came from the factory and the one that has proven itself for the last ten years. All in all I don?t recommend this product because of the possible clearance problem with some trailers and the fact that bearing buddy doesn?t inform the buyer of the problem until after the product arrives.
