Re: Project "1600 Capri Hard Top" has begun!
Huron Angler, that is something to think about.  Thats what I like about these forums, people always have suggestions and ideas.
Got some help from my 18 yr old son James.  He helped me take the Force off to thread in the end of a new steering cable.  Then we put the top on.
Woo Hoo!
A large D bulb seal is used to seal the top to the boat.  You might be able to see a thick black line all around the base of the top, thats the D seal.
Right now it only has a few bolts holding it on, seem to have misplaced 4 of the 8 bolts that hold it.  Oh well....  Off to the hardware store...
The paint is close, but not an exact match.  I was hoping for a better match.  In the bright light it doesn't look off by much.  The tinted windows look good with the tinted hatch.
Now the gas tank can be installed permanently.  I didn't tighten the clamps and strap it down because it had to come out to get to the lower motor mount bolts.  It was a good feeling to pull the bolts out of the transom and find bone dry dust come out with them.  Looks like they used 4200 at the factory to seal the bolts.  I did the same.
The gas springs are both on the port side now and it works really well.  There is enough force to hold the window open even if bouncing around on the waves.
Its really hot outside.  So I stopped and put on the AC and will wait until things cool a bit outside before going back to work.
