hwsiii
- Jan 25, 2009
- 2,639
Re: Prop advice to reach 6000RPM - Negative Slip?
Trend, I got your message so I ran some charts on your two props and they are enclosed. I really love the Solas Amita 4 blade props, but unless you are having a problem with being able to hold a constant speed in a head sea you appear to have a very good prop for your boat in the BRP 15" pitch, you are a little light in RPM but well within the upper motor limits of recommended RPM between 5,000 and 6,000 RPM, and even if you lose 200 RPM with a regular load you are still at 5,500 and if I were you I would look at raising the motor one more notch up, that will probably gain you 150 to 200 RPM at WOT and put you right at maximum RPM, if it doesn't start ventilating.
Speed and Slip
The next chart shows the Effective prop pitch, which is how much pitch is required to make the boat attain the speed it is attaining if there were ZERO prop slip from both props. If you will notice the 16" prop is actually producing 15.22" of pitch and the 18" is only producing 15.68" of pitch and it is a full 2" of theoretical pitch more than the other prop. This is a prime example of how much difference is attributed to the differences in blade geometry between props.
Speed and Effective Prop Pith
H
Speed and Slip
H
