steelespike
- Apr 26, 2002
- 19,069
Speaking very basically a carbed motor wot gph will be about 12 to 14% of the rated hp. A 100 hp will use about 12 to 14 gallons per hour at wide open throttle.
Changing props shouldn't change wot fuel use. If boat speed increases a slight fuel savings may happen as you will get from here to there quicker.
MPG is changed by the resulting speed increase or decrease. Increasing pitch lowers rpm and may slow hole shot may be more sensitive to added weight.
Basically very little change and very likely will even out over the various activities.
As far as your initial numbers there is an error somewhere and its not the calculator. Assuming the gps is accurate at 54 kvh I feel your 14" prop will net about 38.7 mph This will depend heavily on how much rpm you lose with the 14" prop.
