dingbat
- Nov 20, 2001
- 16,566
Thrust washer comes with the hub kit.So that hub kit with the thrust washer I linked should work then?
What hub and washer are you using now?
Ok good, I'll get that kit then. I do believe my outdrive is a gen 2.Not a merc guy….so not familiar with part numbers other than those noted on the box
Shouldn’t matter. Kit comes with appropriate thrust washer
Normally gen 2 have a flat annode, maybe some of the non PS 3.0 s had them. Either way trim the tab and get on with your boatingOk good, I'll get that kit then. I do believe my outdrive is a gen 2.
