Prop Puller
sixgun95
07 Merc 5.0 Alpha Drive. Is a prop puller needed to remove a prop? Is this a tool I must have on the boat with my spare prop?
TilliamWe
Banned
Re: Prop Puller
You'll get plenty of info on here. Or you can check the first reply to your post on TBM.
Re: Prop Puller
Nope,.......
At least Not as long as the propshaft was Greased before the prop was installed.......
And,....
If you Don't grease it,.... It usually takes Alot more than a puller to get it off,.....
More like Grinders,+ Torches.......
Hashi
Re: Prop Puller
As Bond-o says, no puller needed as long as prop shaft was greased. Should slide right off after removing nut. When you replace prop, make sure you grease the splines. I use Merc. teflon grease available at any boating supply store.
