JJB
- Dec 28, 2006
- 274
I have a 20' bayliner with a 175 Johnson on it . The motor is raised to where cave plate is 1" above bottom of V and at max mounting height on boat . I had a 18" 4 blade apollo ss prop to start with and got around 5200 max wot . I then put a solas aluminum 3 blade 17" prop and my rpm drop to 5100 max wot . Some have suggest to use a jack plate to raise engine height which I am considering doing but need to know if my hydraulic steering will work with it . I have been told there is a small hook in the hull , would this effect the max rpm I am able to reach with this boat and motor ? Thanks for all your input on this one ! .
