Prop question
Sroberts882
Ok went ahead and ordered the solas Amita 4 blade 14.25x19p. The height of it is about 1/8 different then the old prop. I will do another wot test once this blade is put on. I've also read where some props take different thrust washers than others. How do you know which one is the right one and also should I have a splined washer that goes on after the prop. Thanks.
Sroberts882
I believe I got it finished. Had to go buy a OEM thrust washer and a spindle washer. What torque should you apply to the prop shaft nut
alldodge
Ya know your probably right, I never noticed that this was a Volvo drive (folks hate to post what there working on for some reason). After going back thru all the threads I see where post 23 showed an SX drive posted by DonS. I was going from the Alpha Gen 2 being it was a 2000 model.
My bad
