SEGAangler
- Jun 23, 2013
- 69
I've got a 1987 Evinrude 140 (E140TXCUA). I had a seal failure on the lower unit which ultimately led to seized bearings and a snapped driveshaft. I've replaced the lower unit and I'm using the damaged unit for my own personal learning experience by disassembling it. I cannot remove the pinion gear; I cannot remove the pinion gear nut because there is no shaft to hold to keep from turning. Is there any way to remove the clutch dog pin or disconnect the shift pin or related parts to remove the prop shaft with the pinion gear still in the housing?
