Re: Prop shaft repair question for a little 25hp.
Just a few ideas...can't for sure how well they'd work.<br /><br />But, figuring if you go the sleeve route, you'd really only need to rely on having the stainless sleeve more or less centered on the seal...so why not just cut one in half, and use whatever you fancy to fill in the space between the two.<br /><br />And and even simpler and cheaper solution, would be to try something like JB weld, or any other 2-part epoxy than can stand up to some abuse...certainly inexpensive to try, can be ground/sanded to form fairly easily.<br /><br />I know the task of replacing seals if the above solution fails, is not the most fun...but in the overall scheme of things, if it did work, it'd sure be a heck of a lot cheaper than the alternatives.<br /><br />Not knowing what's at you're disposal...you could theoretically even slice a slab of something like aluminum to fill in the groove (then glue it place, put sleeves over the ends, or just screw it into the prop shaft)...the aluminum could also be machined/sanded fairly easily, and would hold up as well as the epoxy.<br /><br />What comes to mind, is affixing the prop shaft to a drill press, and setting up a jig to hold things secure so you can take a file to it and create an even round surface.<br /><br />Aside from that, there's no reason to suspect that you couldn't just sand things (whatever you use to fill the gap) done so patiently by hand...true, granted machine shops due a guaranteed job in a fraction of the time, but don't forget what mankind and our ancestors came up w/ just by using simple tools, and proper techniques, to get what's needed...tinkering is a gift, success a blessing.<br /><br />Also...the stainless canbe welded, ideally w/ a MIG or TIG set for stainless...but you can also MIG weld steel onto stainless using standard ER70S wire (and probably gas weld it as well)...you'd have the potential for rust, but w/ regular use being turned in fresh water, the seals would hold up for some time...just ideas on how to do it the "cheap" way.<br /><br />Still think, if it was my own...I'd cut the speedy sleeve into two shorter ones, and after pressing them where they need to go to make contact w/ the seal, goop up the remaining groove as much as possible (won't make much difference cosmetically or functionally where there is nothing making contact w/ those areas).
