Ideal trim for optimum top speed cruising in an I/O will not be the same setting to use when taking off from dead stop when towing skiers. Inverse applies also.
Ahzzy, try the trim thing, it is free, and hope you can get out on the 4th and have some fun and report back!
Seems like a 17 would put you closer to ideal RPM range, yes.
