The gofast.com calculator is simple. 2.33 is 2.33, RPM is in HZ...5500 is 5500, prop pitch is in inches...19P is 19. Push the title block over Max Speed and you get max speed in MPH....that's a screw turning in wood, not a propeller turning in a movable volume....water. Jump over to your GPS Actual Speed and insert it in MPH. Click on the Prop Slip title block and the block will fill with your slip in percent. Piece of cake.
Single digits and you are doing great. If you get up to 20% you have a tub......or maybe a TUG towing barges. (sorry just slipped out). Grin
