Re: Prop???
There is a prop forum - I'm sure one of the mods will move this for you so don't post twice.
The "prop guys" will need to know more about your current performance. What it WOT speed with current prop? Is it aluminum? The specs you gave on the prop seem odd - is it a 3-blade 19" pitch? Is the current prop damaged? Boat weight?
Your boat is a bit underpowered, especially for water sports. SS gets you a bit better performcance but less so as the engine hp goes down, from what I understand. It may be you'll want two props with that boat - maybe a 19" for general cruising around and a 17" for water sports to get up and moving with more power.
Again, the prop guys will get you squared away, i'm still a bit of a novice but have picked up some useful info here.
hmmmm....was tis already in the Prop forum!?!? I'm losing it......
