I have a 1986 Force 125hp H1251X6B. I need to replace the shaft seal but I have not been able to break free the shaft spool. (The 4 cap screws removed easily) I have threaded rod screwed into the anti-corrosion screw holes and using a harmonic puller purched on top of the propeller shaft. I have been soaking with Blaster then by Corrosion Block from the propeller side and also through the water inlets. I've used a propane torch to heat the gear case. I've used a slide hammer on the threaded rod (not too agressive) but have not been able to get it to budge. I don't see any corrosion on the top of the spool or the inside of the gear case. I just got the motor so I do not know if the seals ever have been replace before.
My questions are:
1. Can I do internal damage if i put too much down pressure on the propeller shaft since the harmonic balancer sits on top of the propeller shaft?
Would it be better to run the threaded rod through a steel bar and set the steel bar across the top of the gear case opening (one on each side of the propeller shaft) so that the force is spread across the gear case and not the top of the propeller shaft? I have been concerned about putting too much stress on the propeller shaft so I may not be applying enough force to break it free.
2. Should I have it in a specific gear (Forward, Neutral Reverse)?
3. Any Tricks or suggestions? I've read that you can put a piece between the propeller and the gear case, and screw the propeller nut to pull the shaft out. Are there any risks of potential damage using this method? Does it have to be in a specific gear.
Any an all suggestions welcome.
Thank you in advance for your time.
My questions are:
