The bonding wire is confusing me. I have been on ASME Standard committees so I‘m a bit critical on the clarity of standards. Assuming the reference below is actually from the ABYC standard, the committee that wrote this standard definitely needs help on clarifying their standard as in my opinion it is written horribly. 11.4.9 and 11.4.10 is a prime example. 2 different definitions for the same term. This is how you blow things up in industry!
My interpretation:
Electrical Grounding:, All electrical items are grounded to the battery via a black wire.
Structural Grounding: All structural items are grounded to the motor via a lug on the motor, with a green wire.
Are both of these grounds connected to the battery, or just the electrical ground? See 11.4.11 below. The site referenced below shows both connected to the battery.
If both are connected to the battery, then is it just 2 separate grounding circuits, one for electrical (black wire) and one for structural (green wire), correct?
Below is from the
https://newboatbuilders.com/pages/electricity6.html, supposably from the ABYC standard.
In the Bonding description, what is the earth ground?
Bonding: A separate system electrically connecting all metal fittings on the boat that are in contact with the water,
including the sacrificial anode(s), and connecting them to the earth ground, so they are all at the same voltage potential, zero. There should never be any current in the bonding system. The resistance of this circuit should be less than one (1) ohm.
Bonding wire: The bonding wire, also a green wire, is connected to earth ground at the engine negative terminal or the grounding buss.
11.4.9 DC Grounded Conductor - a current carrying conductor connected to the side of the power source that is intentionally maintained at boat ground potential.
11.4.10 DC Grounding Conductor - a normally non current carrying conductor used to connect metallic non current carrying parts of direct current devices to the engine negative terminal, or its bus.
11.4.11 Engine Negative Terminal - the point on the engine at which the negative battery cable is connected.
