Proud father of twins...165s...pics
ErieRon
Re: Proud father of twins...165s...pics
OK...besides that...............
EDIT: Yeah...what he said^^^
C'mon though...mine's 25 years old
jaxnjil
There are basically two types of threads about 470s and OMCs:
Type #1 These are from someone asking about a potential purchase, and
Type #2 These are from someone who already owns the aforementioned.
It would sure seem to me that our responses should differentiate between the two. In the case of #1s, I would think we should nicely explain why these particular packages are best avoided. In the case of #2s we should nicely help those who own them make good decisions going forward. I see no reason to tell #2s that they are screwed, especially #2s who suggest they understand that theirs is not a perfect world . . .
well said Q C
jason GET YOUR FACTS STRAIGHT really now your ripping on 454's to??
Don S
I also know a guy with a 59 Edsel that loves his car has had it sense new and thinks it's a great car. But he also doesn't recommend it to anyone else knowing nothing about cars, as the best thing since sliced bread.
I don't bash the 470 engines anymore and not really sure I ever did bash them, and I also don't say they are great and wonderful and the best thing Mercruiser ever designed. What I do now, is list the problems they have, charging, cam seals, open deck, overheat problems, etc. to people wanting to know if they should buy it or not. If they aren't mechanically inclined, I say NO. IF someone buys a boat and knows nothing about it, I give the same information/advise. If they decide to keep it and make it work, then I help them fix it.
mdlee
To all that hate on the little 3.7l. Yes the iron heads and the aluminum block is a little uncommon. Let?s compare it to the 5.7 Chevy. I am a huge Chevy fan and I can tell you I have never seen the loved 350 run hot and not need the heads reworked. The trick to making the 350 last so long is to not run it hot? same with the little 3.7L. Running a motor hot is an operator error not the fault of the motor. There are gauges in all shapes, sizes and configurations, If you run a motor hot than, you killed it. The motor did not do it to its self.
Don S
2. Cylinder head. It's aluminum. Which isn't a problem in itself because of closed cooling. But if the closed cooling system develops a leak, and they all seem to do on 470's. Go to basic chemistry. 2 dissimilar metals plus an electrolyte makes a battery. With a 470 it's 3 metals, Cast iron, aluminum head, and steel head gasket. Add saltwater to it and corrosion sets in VERY QUICKLY.'
3. Aluminum cylinder head.... again. It shouldn't be in a boat. Most every boat engine has overheated at least once in it's life. Aluminum heads do not take well to even slight to moderate overheats and quickly warp. And oh yeah, a severe overheat will warp and ruin the head, but also warp and ruin the "open deck" block.
4. Aluminum head.... again and again. It's not a DIY job. Sure you can swap the head. But there are special tools involved with setting the valve lash. And to set the lash, you replace pushrods. Not a user friendly way of doing it. You can sit for weeks waiting for 1 pushrod to come in to finish what should be a simple job, what is a simple job on every other motor. That is, if you can even get them. Most parts are NLA for 470's.
Jason, three times you said the 470's had an aluminum head.
They don't, they are Cast Iron Ford 460 heads.
Makes everything else you pointed out questionable.
JustJason
Don and the rest of you guys that jumped on me. You obviously are all correct. When I was writing all that down I had them backwards in my head for some reason.
My boating season ended last month and i've been repairing nothing but snowblowers and generators the last 4 weeks straight.
I think I have TMDETC syndrome... :)
to many damm engines to count.
Don S
Hope you do a better job working on all those engines than you do posting rants.
Your customers may not be happy with you if you don't :eek: :p :p
Take it easy my friend, and say the same things to me when I get grumpy. :)
stonyloam
Had mine since 91 (87 4winns). Let's see: Replaced 2 starters, voltage regulator (alternator kit next time), cam seals (once), that little plug on the back of the head, Head gasket and valve job this past summer. Not too bad for a 22 year old motor, and when is the last time you read about a 3.7 with a "cracked/frozen block" here, I'll bet never. They are 200 lbs lighter (each) than a 4.3. You gotta keep them cool, change impellers often, and make sure the heat exchangers are in good shape. Mine has never left me stranded. Welcome to the "470 club".:eek: Good luck:D
gettin'even
Naaaa that's cool man.
I'll just break it down by systems for ya.
1. Mechanicals... A block is a block. but the 470 uses an open deck block. There are 3 basic types of blocks. Open deck, semi-closed deck, and closed deck. Out of the 3, open decks are the least expensive to manufacture, and also the least reliable. In any application, open deck blocks are more prone to head gasket issues than their closed deck counterparts.
I'll give you this one...An open deck is less reliable, but still does work.
The head is cast iron, the block is aluminum. My Mustang has a cast iron block and alumin heads. I have had this combo for 8 years, and it still runs fine.....
The head is still cast iron....
And again, the head is still cast iron. And custom length pushrods are not that hard to come by....
5. The charging system, we all know about that and how parts to repair are THOUSANDS if they are even available at all. The voltage regulator/rectifier well set you back a cool $700. If you have twin... Double your pleasure double your expense.
Heck, it cost's $500+ just to do an alternator conversion on 1 engine, let alone 2. On top of that... because of the boat design you may not even have the room to do the conversion. Or even worse, You have the room to do it on 1 engine but not the other because the motors are to tight together.
IF a regulator fails, the conversion is actually close to $300. That's if you don't like to watch the gauges supplied by the boat manu...
6. The charging system... again, most every boat i've seen with a 470 the engine needs to come out to pull the flywheel. There is just not enough room in the engine bay to use the proper tool to remove and install the flywheel. And if you hack the flywheel off or hammer it on without using the tool... well that's another grand.
Again......watch the gauges that are already there...and don't let the engine overheat.
7. Cam/water pump oil seals. Same deal as the charging system. To replace a $10 oil seal you need to
A. pull the drive
B. disconnect everything, and pull the engine
C. remove the flywheel and stator
D. remove the front cover
E. remove the water pump
F. remove and re-install the oil seals... and hope the cover doesn't crack in the process. Because they are really really really thin and easy to crack... and they are NLA if you break it
G. Put it all back together, re-install the engine, align it, re-install the drive. Water test it and hope you got all the water out of the oil
F. A $10 part just turned into a thousand dollar job
Wow...if you break the front cover when replacing the seals, you really shouldn't be working on a boat...or a lawn mower, or anything mehanical.
8. The cooling system. It was under par on the earlier models. On some they used a 3 inch heat exchanger. They are prone to overheating. This was fixed by going to a 4 inch exchanger. If you have a boat with 3 inch exchangers you need to really watch your temps, but really you should swap them out for the 4 inch models. Double your pleasure with twin engine rigs
Yep..the 4 inchers are the way to go. not really a big deal to replace if you have the small er 3 inchers.
9. Because mechanic's don't like working on 470's. And if you have to bring a boat into a shop customers will often get charged top dollar for anything other than an oil change. And they will also get charged what's called in the industry as the FU Surcharge :)
Have yet to verify this, but you must know what you're talkin' about...I guess....
I still feel my initial post on the thread was still the correct advice.
gettin'even
I have definately had my "issues" with my 470, but most are related to teh engine being 22 years old, all original, and my inexperience with boats in general. Mine has also never left me stranded, no matter what went wrong at the time. I don't think these engines are awesome, but I don't feel they are as bad as most would want you to think.
my $.02
rockyman
it sounds like everyone is comparing apples to oranges here, so here is my opion , chevy tried matching alluminum to cast iron with vega and that did not work either.
oldsub86
Not everyone had trouble with the Vega either. I had a new Vega in 1974 and it was fine. It was noisy and lacked power but I never had any mechanical issues with the engine.
Randy
(who also has an old OMC stringer)
mdlee
There is some Passion in this Thread!! I like it :D:D
Ayuh,.... And you've still got it,..?? It still runs,..??
Didn't think so....Still apples & oranges anyways,...
The Vega was a closed deck with aluminum cylinders, No liners, No open deck...
