Re: proud new to me 1962 Starcraft Run-about owner
Thanks all.
So I've been throwing around some ideas. I am an avid fisherman and as I've done my research it looks like most folks like restoring the boats. I do want to make it a fishing vessel. My ideas might be blasphemous to some on here, so I hope I do not offend.
Here's what I'm thinking and let me know if you think this can be done.
I want to put in a floor, however I do not have stringers for this. I just have the ribs on the hull. I also don't want to make the boat top heavy so the lower the floor the better. I'm thinking the sub floor would be made out of epoxied wood or aluminum. Aluminum would be better, but epoxied wood might be cheaper.
I want a foot controlled trolling motor on the bow. So here's what I am thinking. Moving the dashboard up a bit on the bow and making the "captains" chair a single pedestal at the steering wheel. The "captains" chair will have the foot pedal for the trolling motor mounted below it. I would cut a hatch to pass the cable through to the chair. I would also build a console to the right of the chair with my wiring, switches and throttle.
I am going to convert the steering from a cable steer to a teleflex system or something a little more updated. Underneath the revised bow cap I would have some storage. I am thinking of adding a fuse block but that would be mounted under the console cap.
Putting the single "captains" chair up front and center and then moving the dashboard would allow me to have two seats in back by the transom with either a small live well (cooler converted) or a cover for the fuel tank. The batteries would be hidden underneath the seats. I will also have two more swivel seats in the middle of the boat.
Last thing I want to do - or first thing - is I want to get a starter put on the motor as it has the bracket for it. I'm running a Johnson 28hp RX-10 super seahorse.
I am not going to cheap this out am going to go for quality, but a little transformation would be OK I think. I have some graphics capabilities and am doing up some schematics and layouts in my drafting programs.
Let me know if you have suggestions or can envisions what I am.
Thanks,
J.T.
