homelite
- Aug 13, 2002
- 159
I need to pull an engine. I see the mounts to the floor are on the engine and then on the trans with bell housing holding it together. Is it common to pull one or the other and block up the component that you are not pulling? Or must you pull both engine and trans, then separate once removed?
What is most common or the best way?
Thanks,
Thanks,
