Re: Purchase 4.3L OMC 2b, 18ft EbbTide Riveria
I don't share Juancho's philosophy on OMC. OMC is a perfectly fine sterndrive company. Parts are available, there are numberous aftermarket companies that still produce its parts. You can occasionally find factory parts too. Some volvo parts will fit your OMC as volvo incorparated some of OMC's designs when they bought it. The reason OMC has such a bad reputation is it had a design flaw in its shift system. The transom shift cable was at fault and needed redesigned. The flawed cable is black, and the redesigned cable is red as to easily spot if your boat has the correct cable. Also, your boat should shift very easily. If not, that means there is trouble and the gears will soon eat themselves. I make sure that my boat is properly maintained and had it upgraded with the red shift cable. My cobra runs and shifts beautifully, and shows no sign of changing. Follow the advice in my earlier post, and it should tell you if this boat is worth deeper consideration. The gear oil is checked by unscrewing the largest and center of the 5 bolts on the top of the outdrive. Since the boat has been sitting, the water (if any) may have settled to the bottom, in which case remove the drain plug on the bottom of the outdrive near the skeg. Its alright if a little bit of water falls out, but anything over a teaspoon, back to the classifieds you go. Take a test drive before you give the seller any money, or you might get a raw deal. A clean engine is nice, but does not tell you how well it is inside. My manifolds and risers looked a day old when I bought my boat, when they came off after I found water in the oil, I found they were rusted though. Looks can be deceiving...
