TheRussian
- Jul 10, 2013
- 142
Hello all,
I am attempting to purge all of the trim fluid from my trim system on an Alpha 1 Gen 2 because of the milky oil (water got in from the top of the reservoir, the system is working fine). So far I have taken off and cleaned out the reservoir and replaced the metal filters which I found to have been torn up. I am not sure how to purge the lines and the rams. The Merc manual does get into purging air but it requires some plugs (don't have) and I also HAVE THE DRIVE IN THE TRAILER position - the manual states to have in trimmed down. I had found Bondo's old instructions on a different site - disconnect the lines on the transom (4 lines total I assume), move the drive up and down by hand and then run the trim pump up and down. Then reconnect.
Is this procedure correct and is it really possible to move the drive up and down by hand after the lines are disconnected?
Also, when I reconnect, does the drive have to be in the initial position when I started the purge?
Thanks in advance.
Thanks in advance.
