pvc sewer pipe for pontoons
ratherbefishin
has anyone built a pontoon boat out of large diameter black PVC sewer pipe using standard fittings?Would this be a practical home building project?
ondarvr
Re: pvc sewer pipe for pontoons
Somebody most likely has, but ABS (the black stuff) and PVC are not that impact resistant, it can seem very tough, but if you hit it just right it will break easily. I don't know the maximum size of ABS, but I haven't seen large diameter ABS pipe anywhere and large diameter PVC pipe and fittings can get pricy.
Modified
I don't think I've really ever seen a large enough PVC pipe to hold up a frame. I've seen those black jugs under a frame to build a dock before though.
MGA
In my neck of the woods we have been using plastic culvert pipe for floats for docks and rafts, we get the manufacture to sonice weld caps on and they work great and have reinforcing around them I believe the company name is Solarno
JB
Don't even think about PVC designed to be underground. That stuff gets brittle very fast when exposed to UV.
If it has a UV inhibitor or is painted with a UV screening paint I guess it would be okay.
Coors
I dunno, JB; I have built a lot of water/waste water plants with exposed PVC, and gone back 6 years later , and all was good.
Schedule 80 is almost bullet-proof at 16" and better.
I have standing hose bibbs of PVC outside, that have lasted 25 years, with freezes..
Just an observation.
Coors
I missed the "sewer" part.
Schedule 80 (high pressure) should work.
Sorry, JB, wasn't paying attention; like my teachers always said in school.
ratherbefishin
a few years ago there was a company[forget the name] building ''rigid hull inflatables'' out of the heavy black pipe for industrial use-they were pretty indestructable.They of course had the ''welding''equipment ,I was thinking of just using existing fittings.I think they used 20''pipe.
Bob_VT
Most of the black plastic culvert pipes I have worked with (up to 4 feet in diameter) have been made from HDPE. The only fault is that they are corrugated on the outside with a smooth pipe inside. You could make one heck of a dock from them.
Coors
Yes, the white pressure pipe(the schedule 80 pipe is black in pressure series)
You could even glue on a 45 degree to the front.
But that stuff ain't light, takes h/e to move a 20' piece, but displacement is displacement..
Can't corrode, paintible, the weight may even make it more stable in rough seas..
burroak
About the only upside to using that stuff would be if it were free.
Downside: weight, sealing out H2O, fastening anything to it, making it hydrodynamic, and how it's going to look.:D
You Might Be A Redneck If..............................
Coors
You can fasten to it, just pretend it's aluminum?
burroak
There are stresses introduced into the PVC during the extrusion process that make it unpredictable. Just cut some of that stuff with a chop saw or circular saw. Most of the time it cuts smoothly and then some times chunks fly out of it.
This idea is fraught with so many uncertainties; there are just other alternatives.
ondarvr
I worked with PVC sch 40 and 80 pipe for 20 years making filtration and irrigation systems, the stuff can be very strong, but if it gets a sharp hit it can shatter instantly. While it could work, I don't think I would trust it.
The PE culvert looks interesting.
Nope,............. But I built a Big 1 out of Propane Tanks,..........
It's probably alittle Bigger than you were Thinking,..............;)
tashasdaddy
that's a barge. how many passengers is it rated for?
burroak
Sure hope those tanks were purged.:D
watermellonI
fill em with pour foam?! cap em off , and git r done
Ayuh,........ Right,............
I guess you haven't been around long enough to know how I feel about Foam............
There's Nothing in that bilge but Rigging,+ Air..........
I guess that would depend on How fat the women are,.........
We've had over 13 Tons on, without issue............
But that was Concrete,+ Not women.....
That's an 8 ton Paver,+ 3 ton Roller in the picture,....
We were going over to an Island to install a Tennis Court last year.........
