somethings not working. Is there a way to check the gauge and the sender to determine which is bad?
C conron Seaman Joined Jun 23, 2010 Messages 55 Jul 4, 2010 #1 somethings not working. Is there a way to check the gauge and the sender to determine which is bad?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,493 Jul 4, 2010 #2 Re: question about fuel gauge with the key on, ground the pink wire at the tank connection.Gauge should show full. Also check to see if tank is grounded . Next use a ohmeter on the sender
