Re: Question about home computer Video Memory?
Hello again,
I took the side panel of the computer in question and to me the memory definitely looks like it is integrated in with the motherboard. So yes I tried to hit all F10, F12, and DELETE and I didn't have any luck but is there a trick I don't know that I need to do to make that work? I really don't want to spend alot of money on my young daughters computer if I can transfer some memory to the video card. Let me know and I think transferring the memory will work if I can figure it out. Thanks, Bob
When your computer FIRST boots, before the windows startup screen, etc. It should do a memory check, etc. It will probably briefly post on the screen what key you need to hit to enter setup. It's probably an F key, but you have to be quick, possibly tapping it a few times. It might take a few tries to get there.
If it's posting to quickly for you to see, try unplugging the keyboard, and resetting. If you use a USB keyboard this won't work. You can unplug the HDD. It will give you a "disk not found" error, and will tell you how to get into the bios to try and fix it.
If all else fails, you can always order another video card, but if it's just for a simple game, there's no reason to spend more money.
Good luck!
