question? about to start restoration to my sea ray 220 bowrider. deck and stringers?
ratking20
ok. tomorrow the boat comes out of the water.
going to pull the engine ASAP. already stripped the boat down to the floor. i mean the seats are gone and anything i could unscrew etc. tomorrow i plan on removing all the carpet and maybe starting to saw the deck. heres my questions. and i will take and post some pics tomorrow, i know thats what everybody wants.
1. should i leave a few inches like i read on this forum on each side. is this just to avoid sawing into and through the hull itself. is there any other reason? and is the idea to then carefully remove the lip with a better tool than a circular saw.
2. when and if i need to do work on the stringers. my guess is at least a little. i simply cut out the bad wood neatly if possible and the cut new wood stringers that fit in. i glue into place the new stringers? using PL? WHAT TYPE OF PL? there are a few kinds. and then i cover them with the polyester resin and csm (i ordered already) im not too sure on the steps i need to take with the stringers. i only plan on replacing what needs to be done. i dont think the bow will have any damage but we will see. any help would be great.
and i do promise to post pictures.
oops!
Re: question? about to start restoration to my sea ray 220 bowrider. deck and stringe
hi rat.
ok.....the lip is to make sure you have the right deck height.......if i am doing a partial deck i will leave it.....if its a full deck....the lip goes.
pl premium or pl mortar or 9000. dont glass over top uncured pl.
you can also use peanut butter.
click the link in my sig for pics and info
cheers
oops
ratking20
ok so i started cutting out the deck, and of course the stringers are going to need work too. seems like only the starboard side will need stringer work, but until i remove alot more deck and foam we will not know fully. alot of water in the foam. ripping the deck up is a pain in the ***. i will get some pics next time so you can see how bad it is.
any tips for removing foam?????
Ciera2450
A flat shovel works well. Or a floor scraper.
