So to set valve lash you tighten the rocker nut until you can feel resistance in the push rod, then you tighten the nut an additional 3/4 or 1 full turn depending on specs.
My question is what is considered resistance on the pushrod? Is it when you can just start to feel some resistance while turning the pushrod?
