Question for JerryJerry
tg3690
Mr. Jerry, was looking at a thread that was closed today for being over 6 years old and it had to do with timing. You showed a pic of your 3-wire plug grounding harness you use. Where the 3 wires come together there is a circle connector or eyelet. Where do you bolt that to to ground it? Thanks.
jerryjerry05
Any bolt/screw that's easily accessed.
The top of the exhaust chest, the corner bolt is usually where.
If you have a clip you can add it to the harness and then ground it to anything that doesn't move.
tg3690
OK sir, thank you.
tg3690
When you said the top of the exhaust chest are you talking about the exhaust port cover? Or on the intake side somewhere?
