So I am modifying an old 1950's Alumacraft 14ft boat with a 1950's 35hp evinrude lark. I have a used teleflex system scavenged from the gentlemen I purchased the motor from. It is the basic mechanical teleflex system known as The Rack.
On the end that mounts to the motor, there is the push/pull mechinism, and at the base of that is a little threaded female connector, see picture:
I believe this is the rear mount for it. I tried hooking mine up without using this, and there is just way too much 'slop' in the system. So basically, I feel I need to find or fabricate something to screw into that opening that I can use to mount the rear of the system.
Basically, the first thing that would be a nice easy cheap fix is using threaded conduit. Its readily available, and I could get it for cheap basically at any hardware store. So I purchased the 1/2" inside diameter as I wanted it to be just slightly larger then the push/pull mechanism. Unfortunately, it looks like the mechanism is 1/2" itself, and it doesn't work. So my next thought is tomorrow I will return it, and try and find a 3/4" piece.
My question is, has anyone every tried to fabricate the mount for the back of this system? Is there something better then conduit that is relatively inexpensive and readily available? I'm not even sure if the 3/4" will fit the existing female connector on the mechanism--im just hoping it will. Assuming it will, it should be a relatively easy fix. If it doesnt work, I have no idea what to do next--which is why I'm posting here, as I would like to have a back-up plan if my plan doesn't work.
Thanks!
Thanks!
