Question regarding oil change.
achris
More fish than mountain goat
Easy-drain tube attached to where the original sump plug was. It's replaced with a long 'hollow' screw that clamps a banjo fitting... Using the tube is the same as pulling the sump plug, provided you have it laying flat, no rises in it.
Chris....
vetplus40
Finally got the boat out today. I ran it at idle and low rpm's for about 10 minutes and let the oil drain for about 10 minutes. The oil level was the same as when I checked it in my driveway. At this point, the engine appears to be 3/4 of a quart less than what the manual says should be in there, but the level looks fine. I thought that I would "follow up" just in case someone else encountered a similar issue.
