I have a new-looking Attwood EPA-compliant primer bulb I took out of a used jetski I recently bought. It had no checkvalve action in either direction so it was useless as a "pump".
I decided to open it up to see what makes them work. I peeled off the clamps and wiggled the fittings out of the ends. It turns out there were 2 valves in this primer but both were so stuck open that hot water or smacking on the counter wouldn't free them up.
So I opened the fittings to see why.
Each fitting contains a shuttle-**** shaped poppet valve and a snap-in retainer. All parts look to be nylon or pp. I pried out a retainer and pulled out a valve. I found fuel varnish coating everything. "Varnish" is an appropriate name for this crap--alcohol and brake cleaner (acetone) couldn't remove it without scrubbing with a rag or swab. I had to use the wooden stick of the swab, or my fingernail to get off the really tough spots. Once clean it all went back together and both valves now work.
Is the $62 BRP assembly I've already ordered made differently, with different materials or better tolerances? I'm not going to sacrifice it to find out.
I don't quite understand why the carbs were spotless but the primer was varnished up. I bought this jetski in February from a guy who only owned it 1 year (23 year old machine) but maybe it had been recently cleaned.
I'm going to get a few feet of the latest & greatest USCG-approved 5/16 fuel hose and make a spare using this primer.
